SBC on a Raspberry Pi 4
David_K
Hello
Is it possible to install SBC on a Raspberry Pi 4 ?
If yes, has someone done it and using it in production mode?
What are the hardware requirements?
Yes it is possible and users on here have acheived it. I recommend doing a search to find these posts. However, Pi 4 isnt a supported configuration yet by 3CX so I would wait if you can or continue down the unsupported route if not.
Thanks but it seems most of the posts are old (3-4 years) and talking about installing the PBX on a Raspberry, not the SBC
There's an article here saying it's "compatible" (so does it means supported?)
https://www.3cx.com/docs/3cx-tunnel-session-border-controller/
But I'd like some real world experiences if it's working or not on a 2GB Raspberry model.
Reactions: David_K
You mean as an SBC or 3CX server?
If you follow that post you can get it working (unsupported) as 3CX server. Or you wait until the upcoming release 16 update 6.
The Pi 4 is not yet supported due to Debian Buster, but it's in the works (both for SBC and PBX).
For now only the 3B+ model is supported.
tdzski5
