Solved SBC PI installer issue with putty
Davdi
Platinum Partner
Anyone familiar with SSH client issues?
I ran the most recent 3CX SBC installer through putty on fresh Pi, but I couldn't get past the 3CX SBC prerequisite screen. I tried ENTER, TAB, SpaceBar nothing seems to work.
I had to ctrl-c to get out of it. Then the command line didnt show properly past the blue install wizard. See image below.
I closed the connection and i tried using ssh command in Microsoft command prompt.
Everything worked first try with cmd.
This isnt a critical issue, but my team is trained and comfortable with putty. I am hoping to figure out what is going on.
Pi running fresh install of the Pi version of Debian 12. I was accessing it from my Windows 10 desktop.
IDK if this is an issue with putty, the 3CX installer wizard, or something else.
Any ideas would be appreciated.
David
Never noticed such issue on putty or raspbian.
Have you checked resolution as well?
Thanks for the suggestion.
I looked into resolution and now I cannot for the life of me reproduce the issue. It was very consistent on Friday. Well, I suppose all's well that ends well...
I'm glad that this fixed the issue ;)
Carlos - EC Mates
