SBC pi zero W
rwest902
simple question will a pi zero W be enough to run an SBC or should I go with my Pi 4B?
well i got it installed will wait for my good phones to test
yup that covers the 3cx PBX server not the SBX thus led to my question to see if anyone had try a pi zero W for the SBC not 3cx. My 3cx is hosted by 3cx right now. I have it installed seems ok heat coming from the pi is minimal via usb->ethernet. once I get my phones I will test them and see what if anything changed or bogs down.
I guess a RPi zero W is not powerful enough to act as SBC, use the RPi 4B instead... that one is recommended.
ya probably for big users. I only have 4 phones or will right now. Also just had the zero laying around worth the test. I wont hold it against 3cx if it fails LOL, I have a few Pi's on order now just in case
@rwest902
Please do bear in mind that we indeed recommend the Raspberry Pi 4 (B4 or B8) as it has been thoroughly tested by 3CX both as a PBX and an SBC. That said, even if you do manage to run the 3CX SBC on a different model, we would not be able to guarantee normal functionality and it would not be considered a 3CX Supported configuration.
Fore more information please do consider taking a look at our hardware requirements guide(ARM-based section): https://www.3cx.com/docs/recommended-hardware-specifications-for-3cx/
K7oR0x
