SBC tunnel encryption vs softphone tunnel?
treefiddy
I was reading the SBC documentation and it specifically states that encryption can be enabled. Is this true? I was under the impression that the tunnel didn't actually do any encryption, though I really wish it did.
9878
Also, this is not some super encryption like TLS. It's a basic obfuscation. If you need security, you want SIP-TLS + SRTP or VPN.
In the system changelog posted above it mentions SSL. "Basic obfuscation" sounds terrible...
It sounds terrible because it is. It was stated at least once here in the forums by a member of the 3CX team that if you really needed encryption not to rely on the tunnel encryption. The primary purpose of the tunnel is easier NAT traversal.
Okay. Thanks for clarifying cobalt.
Actually the SBC encryption uses TLS 1.2 so its quite capable. I believe @cobaltit refers to using the tunnel without encryption that only encapsulates packets and helps with NAT traversal.
@YiannisH_3CX I seem to remember when the encryption was first released nb said it wasn't that strong but I may be wrong. Does 3CX have the specs listed anywhere for that because anyone who needs it would need to know the specifics.
Thanks for the update/correction.
Thanks for this.
Am I correct that the client tunnels are not TLS though? That would be great.
I am afraid the TLS version of the SBC encryption is not documented currently but you can see the handshake using wireshark.
Thanks for this.
Yes that is correct. The clients do not have this option.
florentrobineau
