Secure SIP TLS on Android/IOS 3CX Clients with Custom Domain Not Working
Periklis
Is secure SIP (TLS) supported on Android/IOS 3CX clients when using a non 3CX domain name with our own SSL? Currently the PBX is hosted on the cloud, on a custom subdomain of ours, non 3CX. We purchased and used our own trusted wildcard SSL, and there are no certificate errors, or warnings when accessing the PBX management console from a browser, the certificate shows valid.
All extensions are remote pointing to the PBX FQDN, and the IP of the PBX is static. Our hardware IP phones can register, and do operate with secure SIP and SRTP, both forced; the 3CX soft phones, on the other hand fail to register when TLS is enabled (error:register failed, service unavailable); they only register when TCP, or UDP is used; there is no support for secure SIP.
All ports on the firewalls are configured properly, and the exact same setup was tested with a 3CX subdomain (backup and restore without FQDN), and everything worked as expected, all 3cx sip phones, android and IOS, where able to get registered, and operate with secure SIP and SRTP.
Any input will be greatly appreciated.
Thanks!
@edossantos,
You provided valuable input in the past, can you review this thread?
Thanks!
Similar issue I am experiencing too , I have shred logs and detailed info here
https://www.3cx.com/community/threads/3cx-android-client-secure-sip-tls.60507/
Windows 3CX soft client works fine ,
Android I have issues
I do not have iOS to test
help greatly welcome
Based on my logs, it is a bug in the app which gives and says SSL certi verification failed
I use FQDN cert , no wildcard
Please check my post
Thanks for the input @mobilowa,
Indeed this works fine on windows, i just tested it. I opened up a support ticket with 3CX, i will share any findings.
Many Thanks . . .
Kindly share me what 3CX Support team says
Any workaround, or his will be fixed in next app version release
I believe it is a bug in App in Android n IOS, App failed to verify Custom FQDN certificate issues by commercial CA with error code of "PJSIP_TLS_ECERTVERIF"
Subsequently 3CX android app fails ti send SIP register message to sever over TLS
@mobilowa
I am quoting below the response of 3CX support
"I'm afraid for SIP TLS you will need a certificate specific to your FQDN, no wildcard certificates are accepted as a general rule. As per RFC 5922 (https://tools.ietf.org/html/rfc5922) it is said "this document prohibits such wildcards in certificates for SIP domains.""
I did try using wildcard SSL's, multi domain SSL's, and also a standalone SSL both with www and without www; they all failed, the soft phones were unable to register with secure SIP and SRTP. I will work on a non production machine with a custom domain and a PRO license; if there any further findings, i will post. Feel free to add any of your findings.
Mahlon
