Self-Hosted install via 3CX portal to AWS Lightsail fails
sevenvoip
I have tried to install a new instance in my AWs Lightsail cloud, but I keep getting an error. I get an email that states...
An error was reported during the creation of your 3CX instance with Amazon - Lightsail.
PBX is not started in 00:30:00
Please check the configuration guide for your cloud provider in order to identify the cause of this issue. If you continue to experience difficulties setting up 3CX in your cloud provider, you can seek help from our community.
Try Hosted by 3CX
You can also opt for a cloud solution managed by 3CX, subject to availability in your country. You can do this by logging into your customer portal."
Any ideas? It seems to create the instance n my portal, but none of the 3CX info gets installed on it. This is a recent occurrence as I've used this feature not long ago at all.
cur_cb
