Solved Server Error
anniesandhu
Forum User
not able to login into web 3cx management console as i am entering my id and password it is showing server error
please provide solutions
though my phones are working all fine but management console is giving server error
Reactions: abc2009
Reboot. Since you gave no details as to your setup I'm going to assume this is Debian and due to the postgresql patch pushed out.
Connect SSH with root user
Type :
systemctl list-units --failed
It will tell you which service have "failed" .
After ... type :
systemctl restart %ServiceName%.service
(Replace « %ServiceName% » by the name failed service )
The reboot would be better but it is not always possible to restart the server. My solution generally allows to restart the service without cutting the actives calls.
Reactions: autohaus
Thanks all for giving a couple of solutions
restart the server solved the server error :)
wish you a wonderful day
Glad to see the issue has been resolved and thank you for updating the thread with your solution.
mschzias
