Service not available after configuring the Main trunk number on 3CX
The phone can’t register after configuring the Main trunk number on 3CX. The allocated number is always unavailable for both incoming and outgoing calls
Hi @710 could you please let me know what voip provider are you using with the FREE/SMB installation?
Also are you using any IP Phone? what model and firmware version?
Hi there, not sure which phones you are referring to, that are unable to register, as don't see any phones on your users.
Additionally, adding a main trunk number to your sip trunk is not going to affect the phones.
Can you please clarify exactly what the issue is please?
Thank you for the request, My VoIP Provider is AfriHost (Vox SIP Trunk) and I am using Free SMB.
Yealink SIP-T58A with T58A-58.86.0.39.rom firmware .
Ok, in order to configure that IP phone you must use a SBC connection either using a dedicated sbc or router phone, then you can provisioning the Yealink T58A as normal phone, this is mentioned in the guide
About the sip trunk could you please delete it and create it one more time, check that the main trunk number is set as E164 then configure the call routing to your extension and try to make a test using the web client, PWA or desktop app.
Reactions: Charles_3CX
The Router Phone (Yealink T43U) is working fine, but Yealink SIP-T58A with T58A-58.86.0.39.rom firmware can not re-register after
Can you tell me the FQDN of your 3cx free system? Is it 1481.3cx.cloud?
Reactions: 710
I've configured everything successfully, but the Direct Inward Dialing is failing to route calls to an extension. Your assistance will be highly appreciated.
lastshadow
