- Joined
- Aug 17, 2019
- Messages
- 43
- Reaction score
- 3
Hi Arnie,
You can set custom office hours on specific DIDs or trunks, which will then go to the queue of your choice.
If you don't want to affect the DID (ie. if you have a single DID and then send calls to queues via an IVR) you can use a different method. Create an extension which will act as a Queue Forwarder and set specific hours for that extension under its Forwarding settings, Auto Switch menu.
During Office Hours "Available" should forward calls to the queue, and outside office hours "DND" should forward calls to the destination of your choice.
.Auto Switch just decides what hours you switch to the Available status. It does not decide the destination.
So edit the Availble Forwards to send all calls to the Queue, and edit the DND forwards to send all the calls to the destination outside your work hours.
The system will automatically switch you back and forth (hence applying the forwards you selected for each status)
Can you check the status of the extension
Within 3CX management console - under extensions select the extension and click on the 'Status' buttom along the top.
What is the current status ?. Is it correct for the time of day ?
Out of suggestions.
can you manually change the status to dnd, then check tomorrow to see if the status change to available @ 22:00
Founded in 2005, when VoIP was an emerging technology, 3CX has gone on to establish itself as a global leader in business communications.
