setting up outbound caller ID with nextiva
dydot
Hi guys, needs some help regarding setting up caller id on some of extensions.
What i like to is to set one of extension when dial out it will show our Tollfree number on the other end.
I spoke with nextiva and they said i need to set P-Asserted Identity which i tried and failed.
on the P-Asserted Identity: User Part = OutboundCallerId taken from extension setting in management console
on P-Asserted Identity: Host Part = GWHostPort gateway/provider host/port
on the extension setting- Outbound Caller ID = my Tollfree Number.
is there something i missed on this??
all suggestion are welcome.
logs from 3CX
Code:
03/03/2021 8:33:55 PM - Leg L:262.1[Extn:920] is terminated: Cause: BYE from PBX
03/03/2021 8:33:55 PM - Terminated from "myExt"<sip:[email protected]:5060>;tag=753fce4d to <sip:[email protected]:5060>;tag=314bf52d; reason: Rejected
03/03/2021 8:33:55 PM - L:262.1[Extn:920] Sending: OnSendResp Send 403/INVITE from 0.0.0.0:0 tid=-d8754z-aa6b18548826b300-1---d8754z- Call-ID=MDQxOTQ1NjE5MGRmOThmMzc3NGVhOWQ5NGVkNjBiN2Y.:
SIP/2.0 403 Forbidden
Via: SIP/2.0/UDP 172.20.10.42:54956;branch=z9hG4bK-d8754z-aa6b18548826b300-1---d8754z-;rport=54956
To: <sip:[email protected]:5060>;tag=314bf52d
From: "myExt"<sip:[email protected]:5060>;tag=753fce4d
Call-ID: MDQxOTQ1NjE5MGRmOThmMzc3NGVhOWQ5NGVkNjBiN2Y.
CSeq: 2 INVITE
Warning: 499 DESKTOP-R3635FH "Forbidden"
Content-Length: 0
03/03/2021 8:33:55 PM - SendMsg from <sip:[email protected]:5060>;tag=314bf52d to "myExt"<sip:[email protected]:5060>;tag=753fce4d
03/03/2021 8:33:55 PM - ~Target=Unknown:5014786458@(Ln.10000@Nextiva)
03/03/2021 8:33:55 PM - Call(C:262) is terminated
03/03/2021 8:33:55 PM - Leg L:262.2[Line:10000>>5014786458] is terminated: Cause: 403 Forbidden/INVITE from 208.73.144.74:5060
03/03/2021 8:33:55 PM - [CM503020]: Call(C:262): Normal call termination. Call originator: Extn:920. Reason: Forbidden
03/03/2021 8:33:55 PM - L:262.2[Line:10000>>5014786458] got Terminated Recv 403/INVITE from 208.73.144.74:5060 tid=4f07ae3ab2636f01 Call-ID=gG_RH_TOB2gjWPcvZrYPrA..:
Via: SIP/2.0/UDP 10.10.10.10:5060;received=208.105.44.162;branch=z9hG4bK-524287-1---4f07ae3ab2636f01;rport=5060
To: <sip:[email protected]>;tag=aprqngfrt-sq0fd83000020
From: "8004567890"<sip:[email protected]>;tag=40646009
Call-ID: gG_RH_TOB2gjWPcvZrYPrA..
CSeq: 1 INVITE
Content-Length: 0
03/03/2021 8:33:55 PM - [CM503016]: Call(C:262): Attempt to reach <sip:[email protected]:5060> from Extn:920 has failed. Reason: Forbidden
03/03/2021 8:33:55 PM - Terminated from <sip:[email protected]>;tag=aprqngfrt-sq0fd83000020 to "8004567890"<sip:[email protected]>;tag=40646009; reason: Error
03/03/2021 8:33:55 PM - [Flow] Current call diversion path:[]
03/03/2021 8:33:55 PM - L:262.1[Extn:920] failed to reach Line:10000>>5014786458, reason Forbidden
03/03/2021 8:33:55 PM - RerouteReq
03/03/2021 8:33:55 PM - Call to T:Line:10000>>5014786458@[Dev:sip:[email protected]] from L:262.1[Extn:920] failed, cause: Cause: 403 Forbidden/INVITE from 208.73.144.74:5060
03/03/2021 8:33:55 PM - L:262.2[Line:10000>>5014786458] got Failure: Failure Recv 403/INVITE from 208.73.144.74:5060 tid=4f07ae3ab2636f01 Call-ID=gG_RH_TOB2gjWPcvZrYPrA..:
CSeq: 1 INVITE
Content-Length: 0
03/03/2021 8:33:55 PM - [CM503003]: Call(C:262): Call to <sip:[email protected]:0> has failed; Cause: 403 Forbidden/INVITE from 208.73.144.74:5060
03/03/2021 8:33:55 PM - Session 92170 has failed in leg L:262.2[Line:10000>>5014786458] ; Cause: 403 Forbidden/INVITE from 208.73.144.74:5060
03/03/2021 8:33:55 PM - Failure from <sip:[email protected]>;tag=aprqngfrt-sq0fd83000020 to "8004567890"<sip:[email protected]>;tag=40646009
03/03/2021 8:33:55 PM - [CM503025]: Call(C:262): Calling T:Line:10000>>5014786458@[Dev:sip:[email protected]] for L:262.1[Extn:920]
03/03/2021 8:33:55 PM - Route to L:262.2[Line:10000>>5014786458] sends Invite-OUT Send Req INVITE from 208.73.144.74:5060 tid=4f07ae3ab2636f01 Call-ID=gG_RH_TOB2gjWPcvZrYPrA..:
INVITE sip:[email protected] SIP/2.0
Via: SIP/2.0/ ;branch=z9hG4bK-524287-1---4f07ae3ab2636f01;rport
Max-Forwards: 70
Contact: <sip:[email protected]:5060>
CSeq: 1 INVITE
Allow: INVITE, ACK, CANCEL, OPTIONS, BYE, REGISTER, SUBSCRIBE, NOTIFY, REFER, INFO, MESSAGE, UPDATE
Content-Type: application/sdp
Supported: replaces, timer
User-Agent: 3CXPhoneSystem 16.0.8.9 (9)
P-Asserted-Identity: <sip:[email protected]>
Remote-Party-ID: "8004567890"<sip:[email protected]>;party=calling
Content-Length: 282
v=0
o=3cxPS 457044918272 110763180033 IN IP4 208.105.44.162
s=3cxPS Audio call
c=IN IP4 208.105.44.162
t=0 0
m=audio 9402 RTP/AVP 0 8 18 101
a=rtpmap:0 PCMU/8000
a=rtpmap:8 PCMA/8000
a=rtpmap:18 G729/8000
a=fmtp:18 annexb=no
a=rtpmap:101 telephone-event/8000
a=sendrecv
03/03/2021 8:33:55 PM - Outbound CID reformat rule for DN:10000 is disabled (<Rules />)
03/03/2021 8:33:55 PM - Dev(1382686797):[sip:[email protected] / 2015859921]: PBX contact is public IP: <sip:[email protected]:5060/UDP>
03/03/2021 8:33:55 PM - SLA is globally disabled
03/03/2021 8:33:55 PM - Added leg L:262.2[Line:10000>>5014786458]
03/03/2021 8:33:55 PM - [Flow] Call(C:262): making call from L:262.1[Extn:920] to T:Line:10000>>5014786458@[Dev:sip:[email protected]]
03/03/2021 8:33:55 PM - [CM503027]: Call(C:262): From: Extn:920 ("myExt" <sip:[email protected]:5060>)  to  T:Line:10000>>5014786458@[Dev:sip:[email protected]]
03/03/2021 8:33:55 PM - [CM503004]: Call(C:262): Route 1: from L:262.1[Extn:920] to T:Line:10000>>5014786458@[Dev:sip:[email protected]]
03/03/2021 8:33:55 PM - Line limit check: Current # of calls for line Lc:10000(@Nextiva[<sip:[email protected]:0/UDP>]) is 0; limit is 10
03/03/2021 8:33:55 PM - Call(C:262): Call from Extn:920 to 15014786458 matches outbound rule 'out'
03/03/2021 8:33:55 PM - [Flow] Call(C:262): has built target endpoint: Out#:>>Rule{out}>>15014786458 for call from L:262.1[Extn:920]
03/03/2021 8:33:55 PM - [Flow] Target endpoint for 15014786458 is Out#:>>Rule{out}>>15014786458
03/03/2021 8:33:55 PM - Caller '920' is not found in the list of allowed extensions: 101-899
03/03/2021 8:33:55 PM - Selected prefix: 1
03/03/2021 8:33:55 PM - Looking for outbound rule: dialed = [15014786458], processed: [15014786458]; from-ext:
03/03/2021 8:33:55 PM - [Flow] Building target endpoint to 15014786458 from "myExt" <sip:[email protected]:5060>
03/03/2021 8:33:55 PM - [CM503010]: Call(C:262): Making route(s) from Extn:920 to <sip:[email protected]:5060/UDP>
03/03/2021 8:33:55 PM - Remote SDP is set for leg L:262.1[Extn:920]
03/03/2021 8:33:55 PM - [CM505001]: Endpoint Extn:920: Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [3CXPhone 6.0.26523.0] PBX contact: [sip:[email protected]:5060]
03/03/2021 8:33:55 PM - Inbound DID: ''; Phonebook Name: ''
03/03/2021 8:33:55 PM - [CM500002]: Call(C:262): Info on incoming INVITE from Extn:920:
Invite-IN Recv Req INVITE from 172.20.10.42:54956 tid=-d8754z-aa6b18548826b300-1---d8754z- Call-ID=MDQxOTQ1NjE5MGRmOThmMzc3NGVhOWQ5NGVkNjBiN2Y.:
INVITE sip:[email protected]:5060 SIP/2.0
Max-Forwards: 70
Contact: <sip:[email protected]:54956;rinstance=d00917b5e0110088>
CSeq: 2 INVITE
Proxy-Authorization: Digest username="920",realm="3CXPhoneSystem",nonce="414d535c1650ca0359:66e5e7a871c7306e1eddebc51dfba9ff",uri="sip:[email protected]:5060",response="18e194765fa558f14344916eb0b25260",algorithm=MD5
Supported: replaces
User-Agent: 3CXPhone 6.0.26523.0
Content-Length: 403
v=0
o=3cxVCE 21344505 394842480 IN IP4 172.20.10.42
s=3cxVCE Audio Call
c=IN IP4 172.20.10.42
t=0 0
m=audio 40018 RTP/AVP 0 8 3 101
a=rtpmap:3 GSM/8000
a=fmtp:101 0-15
a=ptime:20
a=sendrecv
m=video 40016 RTP/AVP 34
a=rtpmap:34 H263/90000
a=fmtp:34 QCIF=1;CIF=1;SQCIF=1;CIF4=1
a=sendrecv
03/03/2021 8:33:55 PM - [CM503001]: Call(C:262): Incoming call from Extn:920 to <sip:[email protected]:5060>
03/03/2021 8:33:55 PM - IncomingCall: C:262 from <sip:[email protected]:5060/UDP> to <sip:[email protected]:5060/UDP>
03/03/2021 8:33:55 PM - Added leg L:C:262.1[No endpoint yet]
03/03/2021 8:33:55 PM - Call from "myExt"<sip:[email protected]:5060>;tag=753fce4d to <sip:[email protected]:5060>;tag=314bf52d
I suggest you reach back out to Nextiva. They are the one rejecting the call.
Reactions: dydot
Hi @dydot
I agree that you should speak with Nextiva as they may need further configuration to have this working apart from the PAI header.
Or you could switch to one of our supported providers and avoid having to mess around with settings as we provider templates for our supported providers with all the settings pre-configured.
https://www.3cx.com/partners/sip-trunks/
Reactions: dydot
Thank you for replying my post.
i'am working with nextiva support to solve this matter.
for supported providers i will think about it since i've been with nextiva for quite sometime and i have a few clients attached with it.
I will get back as soon as i received any news from Nextiva.
Reactions: YiannisH_3CX
lastshadow
