Solved Setup Single Ring and Double Ring
Oveis
Titanium Partner
Hello Everyone,
I know this is a very simple question, in 3CX V18. how to setup, Single ring for incoming(External) calls and the Double ring for internal calls?
Regards,
You would need to change the template of your phones or you could go on the GUI and do it per phone providing they support it.
The client is HOSTED by 3CX so I cannot use customized Template for the phones.
think you'll have to hop on each phone gui then
For example.
Calls to IVR, External and Queue get added to alert-info field in the INVITE and match whatever is set in the template.
My Yealink's "default" ringtone is "Common" which isnt specified by 3CX.
Therefore, I have to modify a template to adjust common to Ring2.wav or I log in to the GUI > Account > Basic and change ring type to Ring2.wav so internal calls that dont match the above alert-info.
Reactions: Oveis
Solved.
Create a Call Queue then route all external call to that call queue and assign a Single Ring (Ring 1) to that call queue and set it up for each extension's.
Reactions: NicholasP_3CX
