SIM calls to paging speakers\phones
paulcaudill
Platinum Partner
I have a client that is wanting to install a bunch of SIP speakers and use then for paging. My question is in order for them to work they will need to be put into a ring/paging group. When you call that group how many SIM calls are used? If we have 10 sip speakers in the group will that use 10 SIM calls or just one?
Hello @paulcaudill
Please note that paging only needs one Simultaneous call regardless of the number of agents.
Great! thank you
That is what I wanted to hear
Use Multicast instead...
Glad i could help
megalmazan
