Sip Trunk configuration Register/Account based does not work...
ischilling
When trying to setup a "register/account based" trunk, changing the drop down "Type of Authentication" to "Register/Account based" is ignored by the ford and set back to its default "Do not require - IP Based".
Consequently the registration fails.
Is there any way to setup a trunk another way - or a bug work around? It does not work in Edge, Chrome and Firefox in their most recent version.
This problem is reproducible.
This should work perfectly fine, I have done it myself several times, please however provide information on the provider you are trying to install, and whether they are supported or you are trying to setup a "Generic" account.
the provider is sipgate and I would like to use the basic version instead of the team version – I know it works, but the issue isn’t on the provider side. It is a bug in the front-end.
As described, the front-end simple does not store the settings as I want them. I meanwhile tried as trunk: Generic.
The issue is the same, it is a bug in the drop-down field in the front-end, reproducible at least with all modern browsers in their actual version. The drop-down does not change and keeps staying with: Do not require - IP Based under Authentication - Type of Authentication.
I did meanwhile - just to cross check - install 3CX on Windows instead using the Debian version... no surprise, no difference.
I just have setup 2 Generic trunks, first one I select VoIP Provider, second one I select SIP Provider, and encountered no issues.
Please clear the cache memory of all your browsers and try again.
Reactions: NickD_3CX
I meanwhile found that with Edge, I don't have any problem in the Drop-Down and it works... however, Chrome and Firefox - even with cleared cache - do have this issue on my devices. Cookies etc. are enabled / disabled, both doesn't affect the issue and still it is reproducible. Both brothers show the Drop-Down wrong, as said in Edge it is correctly displayed.
However, the work-around to me is now using Edge.
There is absolutely no way this is a bug in the software (...and I don't say this with such certainty too often...) and I know because I do this at least 20 times every day with both Firefox and Chrome (I don't use Edge).
I agree its weird, but its either something with your browsers, or something very wrong with your 3CX install.
fngl
