- Joined
- Feb 16, 2017
- Messages
- 12
- Reaction score
- 0
I have four SIP trunks on my self hosted 3CX instance. It's been running for YEARS without issue. Its updated to the most recent v18 build.
Just ONE of the SIP trunks suddenly will not register... Last success was on April 10th 2022. ALL other SIP trunks are fine. Work after a reboot / etc..
Troubleshooting:
Replaced DNS name with IP
Opened the box up COMPLETELY to the internet
Moved to different host virtual host
No firewall traffic appearing when attempting to connect outbound from 3CX
NetCat attempts SHOWS 5060 is open on the other side AND firewall shows traffic.
Called SIP provider (of course nothing is wrong on their end)
Tested account on a softphone, worked fine...!
GUI Logs:
Support Tool Logs:
02-05-2022 13:32:16:641 | 9 | [CM504005]: Registration failed for: Lc:10000(@Acanac[<sip:[email protected]:5060/UDP>]); Cause: Cause: 408 Request Timeout/REGISTER from local
02-05-2022 13:33:52:420 | 9 | [CM504005]: Registration failed for: Lc:10000(@Acanac[<sip:[email protected]:5060/UDP>]); Cause: Cause: 408 Request Timeout/REGISTER from local
02-05-2022 13:36:24:569 | 9 | [CM504005]: Registration failed for: Lc:10000(@Acanac[<sip:[email protected]:5060/UDP>]); Cause: Cause: 408 Request Timeout/REGISTER from local
02-05-2022 13:38:56:709 | 9 | [CM504005]: Registration failed for: Lc:10000(@Acanac[<sip:[email protected]:5060/UDP>]); Cause: Cause: 408 Request Timeout/REGISTER from local
02-05-2022 13:41:28:840 | 9 | [CM504005]: Registration failed for: Lc:10000(@Acanac[<sip:[email protected]:5060/UDP>]); Cause: Cause: 408 Request Timeout/REGISTER from local
HELP!
Troubleshooting:
GUI Logs:
- Registration at Acanac has failed. Destination (sip:206.80.254.101:5060;lr) is not reachable, DNS error resolving FQDN, or service is not available.
SIP Server ID: 12293 05/02/2022 1:41:28 PM - Registration at Acanac has failed. Destination (sip:206.80.254.101;lr) is not reachable, DNS error resolving FQDN, or service is not available.
SIP Server ID: 12293 05/02/2022 1:38:56 PM
Support Tool Logs:
HELP!
