SMB MoH unavailable - request to add
NWIT Admin
Request: I have a request that custom MoH be added to the SMB edition.
Reasoning: I serve a dozen franchisees (some 3-6 employees where SMB would be perfect, some 15+ that must use pro) where the corporate headquarters requires a corporate MoH. I hardly think that a custom MoH is a PRO edition defining feature. I understand the desire to cut down on support and provide a simple setup for SMB, but MoH?!? Besides, MoH is NOT mentioned as a feature (as far as I could find) for the PRO edition, so it is only by trial and error that I discover this non-starter issue. I also understand that not every feature is listed in the features/pricing page, but that seems a pretty critical one to leave out. Now, I have wasted a free year SMB license for a customer that could really use it (and it helps ease the transition of their VOIP solution), but that's on me for not starting it as a trial first! Not all is lost, I will use it for testing purposes to discover capabilities/limitations and chalk it up to lessons learned.
I digress...any chance 3CX might consider adding MoH to SMB?
For the SMB there is no option to change the global MoH but you do have option to use a custom for the Queues.
I suggest contacting 3CX support directly with your request to add MoH to the SMB edition. They can discuss your issue in more detail and provide information on possible plans or solutions for this feature. Additionally, you can also share your experiences and suggestions on the 3CX Community Forum. Discussing your request with other users and developers can help raise awareness of the feature and increase the chances of it being added in future updates.
VOIPEric
