Solved SNTP Errors
jmh-itsjessnetworks
Hi there!
Im attempting to setup a Polycom vvx 101 phone for a client. It states that it is successfully provisioning but, it does not work due to an "SNTP Error"
Any ideas?
Jessie M. Hadaller
Founder / CEO, iTs Jess Networks
jessie@itsjessnetworks
www.itsjessnetworks.com
So you've setup the phone per this guide, including the factory reset and putting it on the correct firmware?
Set Up VVX Series for 3CX
Reactions: NickD_3CX
Yes I have. It appears that it has started working now. This is strange as I have not came across an error like this before...
Perhaps it was a transient error, the phone was unable to reach the NTP server to find the correct time, and then it recovered after a while.
Next time, provide a screenshot or write down the exact error/behavior in case it is a permanent issue.
Glad to hear it was resolved in the end
Finatra.us
