So confusing - The Free license?
billsecond
I downloaded and installed the 3CX on a VM and using it, it works great. However, I am so confused with what I will get/loose when the license expires?
I have heard in some places, I will get 16 sim calls, other say I will have none. I am very confused. I am half tempted to move my PC clock up to the exp day to see what I will loose.
Please help!
1. On creation, you get a 16SC for 1 year. Also, the first 40-days are now a trial of the Pro to let you try the advanced features.
2. After the 40-days trial, you revert back to Standard 16SC unless you pay the upgrade.
3. After 1 year, your license will be automatically renewed and downgraded to 8SC for free. If needed, you can upgrade to more SC or upgrade to Pro/Ent edition.
Reactions: StefanW
The free license will continue to work, but it will be downgraded automatically from Pro to Standard in 40 days from the activation.
It will drop to 8SC from 16SC after the license expires and auto-renews
Okay, so 100% of the time, if I pay nothing, I will get at least 8SC's, and all of the standard features correct?
As it stands today yes, but may change in the future.
The free versions are subject to change and may be revised in the future but this is correct for now.
If you are happy with the system and need additional features or calls you can of course upgrade the existing free key you already have, otherwise you can remain on free edition.
[email protected].
