Softswitch Question
Boschko
Intermediate Cert.
Do you guys have any cloud-hosted SIP softswitch recommendations? The main job will be handling trunks from multiple suppliers and provide trunks to our clients either on the Hosted 3CX or on-prem. So is it safer to simply go with commercial solution like CloudSwitch, Sippy Softswitch, Genband Softswitch? Or do you guys know any good open source alternatives? Any 2 cents will really be appreciated.
I have worked for a provider who used the Ribbon/Genband solution but this solution worked with unify PBXs.
This was a super heavy weight solution and is designed for lots of calls and so a provider can offer not only SIP but integration with the ability to provide ISDN trunks and POT's lines.
I am cannot comment on how 3CX would get along with this sort of solution but I'm sure if one PBX brand works another should.
Reactions: Boschko
florentrobineau
