Unsupported Solved: Click to call on Android
jsa
Forum User
Hi!
I couldn't find a way to use the click to call function on Android:
When following a "phone link" like in google maps, the Android dialer is opened and the system does not ask to call with 3CX.
Is there a way to enable this function?
Regards
Jonas
Hi Jonas,
This is more of an Android thing than a 3CX thing, so we can't help you with that but try looking up something like
"How to get Android to ask for my choice of phone dialer?"
Hi Jonas,
Hi! Thanks for your answer!
it's a 3CX thing as the app does not show at all in the possible dialers list.
Regards!
Hmm not sure why that would be the case..
I reset the default dialler on a phone now and did get 3CX pop us as an option:
Reactions: Vali_3CX
Can you please tell me:
- your device model
- Android version
- version number of our app
- your device model
- Android version
Model: Nothing Phone
Version: Android 13
App Version: 18.1.3.135
One of my customer report the same on IOS, but did not looked into it atm
I tried to wipe data of the app, uninstalled, reinstalled and reprovisionned it, but it does not looks to help
Tell him to check first with WhatsApp (or any other 3rd-party app)
If WhatsApp is listed in the dialer list, then 3CX client will be also; if not - not.
Sorry but it's not.
Same on android.
Whatsapp is never used in case of traditionnal PSTN
Version: Android 13
Hi Jonas, I was able to test this exact model and version now, but in our case we did get a list of apps that included both 3CX, default dialler, skype..
We do not appear there, because we are not a Android dialler but we can handle call links
So are you sure you cleared the default dialler of Android?
Try the following which is exactly what I did:
- Long-press on the default dialer app icon
- Tap the "i" button
- Tap on "Open by default"
- Now Clear the default
Once this is cleared, you can now go in Chrome for example and tap on result in Google
Since Android does not have a default, you will see a menu pop up at the bottom of your screen. and it will ask you every time what app to use. If you don't set a default, you will always be asked in the future.
Reactions: jsa
You're absolutely right!
Thanks a lot for your help and tests.
Will dig into this for the IOS phone when i get my hands on the phone
Regards.
Reactions: JohnS_3CX
Here's the iOS
Reactions: jsa
Reactions: Vali_3CX
Hi John,
Regarding this: is there a chance 3cx will be considered as a dialer?
I'm asking this because one of my customer has a professional App that only ask for "dialer" apps.
is there a way for 3cx to be used in this case?
That would be outside our scope because our app is exclusively used for VoIP calls via the 3CX system.
Reactions: jsa
Thanks you very much for your answer.
cvanderzwan
