Startup Ring group voicemail
goinghosted79
i have a ring group setup and the no answer destination is voicemail for that ring group but i don't see where i can go and set up how many seconds calls ring to the group or how to access the group's voicemail to record a greeting or whose phones the messages will appear on or to what email address messages will be delivered to
Anyone who is part of the ring group will receive an email with the recording. There is no call-in voicemail menu for the ring groups.
You cannot customize the message heard, it uses the default. You can however send the calls to an IVR first which will inform the caller "Sorry we are closed now, you will be forwarded to our voiemail" and then send them to the destination you want (RG Voicemail) from there with a 1 second timeout.
Is there an update as to when startup will be ready and any features that will be added / adjusted when that happens. I don’t even think we can assign extension numbers or disable voicemail pin on startup which as far as I was told all startup was automatically updated to the pro version, so the features I see now are the pro version options
Netflo
