Startup - SIP Trunks
comerfi
We have a system on AWS marketplace and I'm looking at moving to Startup - however I want to check if we can use a Generic SIP trunk (we are using an Ireland provider, IP Telecom) at present - just a single sip trunk with 12no. ddi's. We also have 2no. SBC's on the system. 8 devices of which 3 are Yealink DECT
I'm afraid that will not be possible - StartUP only allows the use of supported providers.
You will either need to move your numbers to a supported provider, or continue to use a dedicated server as you do now.
lonedigger
