Static IP for 3cx Server
mohan.vineeth1988
New User
I installed the debian 3cx v 16... I got it successfully installed but was assigned a dynamic IP. I need to change the IP to a different one.
If you know your way around Linux then you can SSH and change your IP address.
Otherwise, a reinstallation will be your best option.
In case you go with reinstallation, note that Debian will automatically get an IP via DHCP and will not give you an option to set a static IP.
In that case, press Esc when asked for the hostname.
You will then have the option to view the network configuration page
homeit26
