Strange bug exporting and importing ip blacklist JSON: entries missing
jsa
Forum User
Hello all!
I'm facing a strange bug using the ability to export / import IP blacklist on my 3CX System: when reimporting, some entries are not being imported.
The missing entries exists in the exported JSON
PBX Version: 18.0 (Build 965)
My steps to reproduce:
export IP blacklist as JSON and validate the content contain all entries: here are the 4 last entries:
Delete all entries in IP blacklist
Import the just exported JSON list - control that all entries are well imported: Some entries missing: here the 172.X is missing.
Fun fact: it's alway the same IP's not being imported
Am i missing something?
Regards
JS
Hi, during import the contents of the file are normalized so that:
1) invalid entries
2) expired entries
3) duplicate entries
are removed.
So it could be #3 most likely.
1) invalid entries
2) expired entries
are removed.
I did thinked about that but forgot to add in my post sorry.
I did checked if this IP already exist and this is not the case: this IP isn't listed at all once reimported.
Anyway, if the content is normalized, the export would only list it once no?
Normalization happens during import, not export
The IP is not listed twice in the exported JSON so it's not the case i guess
Did more tests: If i import the exact same file on different system i get a differnt number of ip blacklisted. How is this possible?
Regards
Please i am having a situation here View attachment 33230
Unban ip as administrator
Ensure you're connecting to the right portal /webclient or not
add a whitelisted IP range if needed
Anyway this is not quiet related to this thread.
Please i need assistance. i dont understand all you said.
What should i do now. Please
I'd suggest you to start by reading the documentation and look for a certification but:
- connect as an administrator, not using the webclient portal
- find and click blacklisted IPs
- Find yours
- delete it
- Connect
EDIT: if you cant connect as administrator because of banned IP, change your IP address and follow steps above
georgi
