Sudden and excessive memory consumption
thiago.lemos@nassautecnol
Hello, I'm experiencing an issue with a 3CX V20. The memory consumption suddenly increases, causing the server to crash. Upon reviewing the history, the system operates at around 20% memory usage, but then it abruptly spikes to 100%, leading to a crash and system downtime. This issue is only resolved after the server experiences a completely disproportionate increase in memory usage. Has anyone encountered a similar problem or could provide guidance on how to address this?"
I would suggest opening a ticket to our technical support team for this kind of case.
Are you on Windows or Linux? What process is consuming the memory?
Software Linux DEBIAN.
What specific process is consuming the higher than normal memory?
arming
