- Joined
- Jan 22, 2025
- Messages
- 17
- Reaction score
- 1
We have been using the 3CX system for about 20 months without any major issues. However, since Sunday we have been unable to make outgoing calls to UK landlines.When we try to make a call in the usual way, we get the voice message that "The destination is not available, not registered, or there are no outbound routes."
We have not changed any of the settings in the outbound call rules or anything else and calls to UK mobiles are not affected and can be made as usual. We do not have a specific outbound rule for calls to mobile and they are subject to the outbound rules as applied to any call, including landline calls..
The call routing, whereby you can select a prefix to use a particular DID to make a call, also does not work any longer, and we get the message that there is no route set up for any particular prefix. However, there are rules for the use of refixes. which, gain, hves worked perfectly until yesterday.
Nothing has changed on our system, so I'm wondering if something has changed on the 3CX system or possibly the Telxi SIP trunk that is affecting our ability to make outgoing calls to landlines By incorrectly routing them, which at the moment is not possible which is a serious problem for us. In case it is relevant, there are eight users on the system and one router phone, a Yealink T85W.which sends all calls down a static IP address tunnel to 3CX.
Any thoughts anybody has would be very welcome.
