Supported Operating Systems v16
Sovereign87
Hello
I testing currently the 3cx. First i has installed it with the Debian ISO but here my Hyper-V Server does not show an IP in the Hyper-V Manager (integration tools not work correctly). Now i wanted to install on a Server 2019 Core VM. on the following page: https://www.3cx.com/docs/manual/ i see Server 2019 is supported but the installer from v16 says Server 2012R2 and 2016 and no Core supported.
What is correct now?
Best Regards,
Jan Grimm
Hello
Best Regards,
Jan Grimm
The Windows version supports 2012 R2 and 2016. Core installations are not supported.
If you want, try doing a clean install of a regular Debian 9, then manually install 3CX once your integration tools are installed and working. The 3CX ISO might cause trouble on Hyper-V.
Not that I'm aware of.
Gen2 Debian 9 doesnt go together due to secure boot and drivers of the NIC.
hughesdouglas
