Swapping Yealink T43U from normal phone to router phone
rayt
Hi all, a quick question...
Is there a "simple" way (eg. from the phone's web console maybe) to convert a T43U that is running as a normal phone to run as a router phone, without having to re-provision it?
The user is going to work from a different office for a week (same PBX, different LAN/WAN) and I figured that making it a router phone will be the easiest way for her to just take the phone with her and bring it back again afterwards without having to re-configure each time.
Or would it be easier to just point it to a different router phone when she gets there and change it back when she returns?
Thanks.
You can reset the phone from its web GUI so I’ve done this remotely…it’s been a while but IIRC log in to phone, delete from 3CX, add to 3CX, reset phone. Should be Settings> Upgrade I think.
Reactions: BrunoI_3CX and rayt
Thanks Steve,
Yep, so I need to delete & re-add it for the user in 3CX, then reboot the phone. No worries, I thought that might be the case, but I was just hoping there might be a simple setting somwhere that I could "flick" that swaps it over to be a router phone.
Cheers,
Thanks Steve,
Cheers,
Not doable, it needs to pull the SBC config from 3CX.
You can delete and re-add it to enable this feature but if you will also have to factory reset the phone to make sure it works.
Especially for people that have this option:
Reactions: rayt
Thanks John. No problem. I was just looking for an "easy" way out, but delete & re-add is not that hard ;) .
Cheers
Reactions: JohnS_3CX
HaroonEtp
