Solved Switched my SBC from a Windows computer to Rpi4 - confused as to next step(s)
survivalbloke
I just setup 3CX SBC on a Rpi4. It is fully configured and added to my 3CX console - the status dot in the console is green so it's up and online. I'm confused as to what to do next. I see the PnP provisioning but I'm afraid to do anything at this point for fear of losing my phone.
Can someone give me a play-by-play pretty pretty please?
Some more clarification as to what 'switched' means. If the Windows SBC is still running on one IP and the Pi4 IP running on another then you would simple update the SBC IP address on the phone provisioning tab and reprovision/reboot. If the Windows SBC/PC is off/gone, and the Pi4 SBC is using the IP address previously assigned to the Windows PC then you don't have to do anything.
Sure thing. Currently the phone runs on my windows SBC. I have now created a new SBC on a Rpi. The ip addresses are different and I did see the SBC IP option but wasn't sure if that was the right move. So I will change that IP in that tab, and how do I reprovision? Just reboot the phone? I did see you said "reprovision/reboot" and just for clarification want to make sure those are one and the same.
Change the IP address of the SBC server in the management console, under the Users
Rebooting the phone should pick up the changes.
Reactions: survivalbloke
Worked like a charm - thanks!
Reactions: NickD_3CX
apbGroup
