Switching/scaling to a larger LightSail instance
jrgdnn12
I am adding some extensions to my 3CX installation in Amazon LightSail. I suspect may need to scale up my instance for this to work. I assume the steps to a smooth transition to a larger instance are
1.shut down the instance
2.take a snapshot
3.detach the static IP
3.create a new instance from snapshot (this one will have more memory and vCPU and a bigger burstable zone allowance)
4.reattach the static IP to the new larger instance
5.Wait a couple of weeks. Make sure everything is working as it should and then delete old instance to stop accruing charges..
Please let me know if I am missing any steps.
Thank You
Jorge Alvarez
apbGroup
