T54w - Logo format is not supported
sanch6
I'm trying to upload a custom logo for T54w.
It is on a Entreprise Version 20.0 Update 3 (Build 659 Alpha)
Documentation says the following: Yealink T29G / T46S / T46U / T54S / T54W, .png, 480*272 and admin console: Format .png, width 480, height 272, bitdepth 24.
Here is my file details:
When uploading it I get the error : Logo format is not supported
What I'm doing wrong ?
Thank you
Are you using a PNG?
Also tried with jpeg, even if not listed as supported. Without success...
How are you creating the PNG? Is it a transparent image or something like that?
Tried with Photoshop and Paint.net.
With transparent background or a black one. Same error :(
Try compressing the image using an online service or something.
Same error, also tried with another image for a T58w on another instance in Version 20.0 Update 3 (Build 659 Alpha).
Tried many online image compressor or converter... don't know what I'm doing wrong.
Last time I was able to do it playing with phone template and uploading image to a ftp.
This time I ordered Enterprise licences to make it on "the correct way", but seems more difficult
Please share your image ..
I'll try it on my end and attempt to identify the cause.
Thanks for reporting this, it was an issue in the Alpha build that has been fixed.
You should find the fix in the next Beta build when it comes out.
I was just about to mention that it works directly on the phone itself (through the interface).
So, I was going to assume the issue might be on the 3CX "web interface side". :p
Reactions: sanch6
Thank you all for your support. Will wait the next release then.
Is there any estimated release date ?
Best regards
No ETA yet, but please keep in mind that the current build you are using is Alpha and not intended for production environments. The Beta is usually not very far though, so keep an eye out on our blog posts for more info :)
Hey, just to let you know it's working now with the BETA !
arming
