pnwig Customer Joined Dec 20, 2022 Messages 23 Reaction score 2 Jan 6, 2023 #1 Does anyone have a template for this phone? Thanks
CentrexJ Titanium Partner Advanced Certified Joined May 5, 2009 Messages 1,249 Reaction score 694 Jan 6, 2023 #2 configure it under advanced/fxs-dect
pnwig Customer Joined Dec 20, 2022 Messages 23 Reaction score 2 Jan 6, 2023 #4 So I added the Base there, how do I add handsets?
TheodorosG_3CX Staff member 3CX Support Joined Jan 21, 2020 Messages 4,479 Reaction score 1,420 Jan 6, 2023 #5 The handsets need to register to the base. You may check the guideline below for further clarification: • https://www.3cx.com/sip-phones/yealink-dect-w52p/
pnwig Customer Joined Dec 20, 2022 Messages 23 Reaction score 2 Jan 6, 2023 #6 So just the base is needed on 3cx
TheodorosG_3CX Staff member 3CX Support Joined Jan 21, 2020 Messages 4,479 Reaction score 1,420 Jan 6, 2023 #7 The PBX is connected with the base. From the management console you can also configure which extensions will be assigned. The handsets will then register then to the base. This is all explained in the provided guideline.
