Solved Template for Yealink T28P ??
itgs
I need to add a new extension with autoprovisioning , an old T28P, but there is no choice in the list.
I see only T27P. There are no "T28" series models availables.
What I have to do ???
Thank you
In version 15.5 Sp6, you need to scroll down pass the supported yealink phones, and under the 'end of life' subsection you will see T28 (it is at the very end of the list, scroll down to the bottom)
:Thank you for reply.
Another question: where I can find a supported firmware ?
Now phone have V 2.73.0.50 that 3cx indicate as not supported
Reactions: itgs
Thank you all for support
Glad to see the issue has been resolved
Jake R
