The WinSCP access to 3CX pbx on premise after upgrade to R 20
Alcasys
Before upgrade 3CX was possible the WinSCP access to 3CX pbx folders by root access.
The vmware console root access working right also after upgrade from R 18 to 20.
How is possible a new WinSCP access to 3CX pbx folders ?
Petr Halberstat
Hi there.
You still should be able to use the mentioned application and access it, as in the end of the day you access the OS and its file system, so it should not be any limitation there.
I just accessed some of my v20 stuff using winscp looking into some cert issues. Looks like certs got moved around to different paths too. IE: /var/lib/3cxpbx/Bin/nginx/conf/Instance1 . I may be wrong on that though.
Hi there.
Actually the same path is on V18 too
Carlos - EC Mates
