Transfer voicemail across bridge.
vanguard08
Here's a goofy one:
I'm trying to transfer voicemail across a bridge. Outbound rules work for direct extension dialing and call transfers across the bridge but when checking voicemail and hitting the default option 5 to transfer, any extension outside of local is "extension not found".
Not a big deal or anything, I'll just have them forward the voicemail email, but thought I'd toss it out here to see if there was a way.
Cheers
Hello @vanguard08
You can only transfer a voicemail ti an extension that is located in the same server as you. As extensions across a bridge belong to a different system you cannot transfer voicemail messages to them.
I believe the best way is the one you are currently using.
Thanks @YiannisH_3CX
I figured as much, but always good to have confirmation.
Reactions: YiannisH_3CX
SpacetelSupport
