Trial for 3CX Pro License
Kwang Mien
Gold Partner
I would like to trial the 3CX Pro License.
When i download and install the license from this URL, it is actually the 3CX Standard License
https://www.3cx.com/phone-system/download-phone-system/
May I know if 3CX provide any 3CX Pro License for Trial ?
Thanks.
Regards,
Kwang Mien
yes, you as a partner can convert this license into a POC from your customer portal.
Link the license key to your reseller ID to appear in your portal.
Once there, under More you can select POC.
In my customer portal, do I select "Key" and select "Create Try License" ?
can you elaborate regarding how to link the license key to my reseller ID ?
Thanks.
I have linked to my partner account. However, the License is still the Standard License.
May I know how can i change it to Pro License ?
Thanks.
Contact your partner manager (listed in the partner portal) for instructions.
[email protected].
