Solved Trouble provisioning yealink t26p using DirectSIP
katestone
The yealink t26p is on the latest firmware from yealink, 6.73.0.50.
I've reset, and tried to use the Provisioning Link. It says configuration updating, but nothing happens.
I've disabled, Only Accept Trusted Certificates.
If there another way to configure these to work?
I'm running on amazon lightsail.
Yes, this is the guide i followed.
You may have missed this at the bottom of that guide:
9497
Reactions: katestone
At the bottom of Settings > Security:
9498
You'll want to uncheck that.
Yes, perfect, thank you. I did miss that.
I can confirm that worked.
Also, running through an SBC worked for me as well.
Reactions: YiannisH_3CX
Nice, thanks for confirming.
Rich Hopkins
