- Joined
- Sep 25, 2025
- Messages
- 2
- Reaction score
- 0
HI, I am doing a trunk-to-trunk integration with a service that my client needs to use, but the provider of that service tells me the following:
For incoming calls, please note that the numbers belong to your telephony system, not to our trunk.
Our SIP trunk (IP: xx.xx.xxx.x) is only a connection point between your 3CX and our platform. It doesn't host or own any phone numbers.
So, when someone calls your number (e.g. +525512345678), the call first reaches your telephony provider / 3CX.
You then need to configure your 3CX to forward that call to our SIP trunk.
If this routing isn’t configured, our platform will never receive the incoming call.
My question is, how can I forward my trunk number based on username and password to the provider's IP if it doesn't have a number, only an IP?
The same thing happens if you want to generate a call from your platform through my platform:
For outgoing calls, we're sending the SIP INVITE to your 3CX with the correct credentials, but your 3CX replies “403 Forbidden.”
That means your 3CX is rejecting the authentication request.
Please verify that the trunk on your 3CX is configured to accept username/password authentication (not IP-based).
Obviously, my trunk is based on username and password without IP authentication. Is this configuration possible with that provider, at least according to what it is requesting from me in the settings?
Best regards
Best regards
