Unsupported Two Extensions on one Snom Phone
Vettel
Hi 3CX-Community,
how can I provisoning two extensions on one Snom Phone?
Thanks for your help!
Hi @Vettel
We do not support provisioning multiple extensions on deskphones.
If you do so anyway, expect issues.
Ok. Thanks for your answer.
Although it is not supported, you can manually configure line buttons on the Snom Deskphone. You will need to get into the GUI of the phone itself.
I used previously Snom 720 and now D785 and with both I have set 2 SIP account since years one provided by PBX provisioning and second set manually directly on the phone
Never got any problem, just remember if you do it , in case of factory reset you will need to re set manually the second account
