UK Calls Suddenly Stopped working with +44 (Local UK Prefix) and E164 enabled - Nothing changed
pawsius
I have used 3CX for several years and have outbound routes enabled and E164 enabled for UK +44 whiich should strip the + as usual....but it is not...looking in the call logs, it is not stripping the + for UK calls as the appear in the log as +4xxxx but for other countries it strips the + and adds the correct 00. They work fine but any UK number saved as +44 fails
"Target endpoint for +4477xxxxxxxxx can not be built " is what the log shows for each and every call.
004477xxxxxxxxxxxxx is fine
077xxxxxxxxxxxxxx is fine
+971 56xxxxxxxx (e.g.international) is fine
It just started happening with the last update to 16.0.641 on Linux.
Any thoughts Thanks
I sounds like the E164 rues are not being followed, if they appear to be correct.
Perhaps there is some corruption as a result of the update. +44, on UK number not converted to the correct prefix before proceeding to the outbound rules.
Have you tried a re-boot?
Have you tried changing the rules (or deleting), then changing back, to the correct settings?
Most kind suggestions but I have tried all of these. The logs show that with E164 enabled and country set to +44 United Kingdom, it leaves +44xxx number with the + sign
I tried a full reinstall using older backups and when it upgrades to the latest V16.0.641 it stops stripping the +
Is it an option to disable the e164 rules and just manually set the required rule in the outbound rules? I also had issues with teh e164 rule automation and just abandoned it and used outbound rules. Does it work for you?
[email protected].
