Here are the log messages from the App log, found from he phone's web interface (cleansed of specific MAC and subnet info):
000009.536|log |*|03|---------- Initial log entry ----------
000009.538|so |*|03|Platform: Model=SoundPoint IP 550, Assembly=2345-12500-001 Rev=Y Region=
000009.538|so |*|03|Platform: Interface eth0 MAC=0004f2xxxxxx
000009.538|so |*|03|Platform: BootBlock=3.0.2.0024 (12500-001) 30-Nov-10 15:00
000009.538|so |*|03|Platform: Updater=5.0.10.0028 18-Jan-16 15:17
000009.538|so |*|03|Application, main: Label=SIP, Version=Mink 4.0.10.0689 22-Apr-16 12:08
000009.538|so |*|03|Application, main: P/N=3150-11530-409
000009.538|rdisk|*|03|RAM disk created, size: 4,194,304 bytes
000009.538|ocsp |*|03|O.C.S.P. Enabled = 0
000009.540|tls |*|03|Initial log entry. Current logging level 4
000009.578|pmt |*|03|Initial log entry. Current logging level 4
000009.580|wdog |*|03|Initial log entry. Current logging level 4
000009.580|ethf |*|03|Initial log entry. Current logging level 4
000009.580|hw |*|03|Initial log entry. Current logging level 4
000009.580|ares |*|03|Initial log entry. Current logging level 4
000009.580|dns |*|03|Initial log entry. Current logging level 4
000009.580|cfg |*|03|Initial log entry. Current logging level 4
000009.582|dot1x|*|03|Initial log entry. Current logging level 4
000009.586|cfg |5|03|RT|Error installing DHCP event hook.
000009.646|lic |*|03|Initial log entry. Current logging level 4
000009.854|curl |*|03|Initial log entry. Current logging level 4
000009.854|utilm|*|03|Initial log entry. Current logging level 4
000009.854|copy |*|03|Initial log entry. Current logging level 4
000009.854|rtos |*|03|Initial log entry. Current logging level 4
000009.856|sec |*|03|Initial log entry. Current logging level 4
000009.856|so |*|03|Configuration files:
000009.906|log |*|03|Log render level set to 1
000009.950|srtp |*|03|Initial log entry. Current logging level 4
000009.950|res |*|03|Initial log entry. Current logging level 4
000009.954|httpa|*|03|Initial log entry. Current logging level 4
000009.954|lldp |*|03|Initial log entry. Current logging level 4
000009.954|cdp |*|03|Initial log entry. Current logging level 4
000009.954|sys |*|03|Initial log entry. Current logging level 4
000010.048|ssps |*|03|Initial log entry. Current logging level 4
000012.402|so |*|03|System Info Reports:
000012.402|so |*|03| CPU is TNETV1055/C55x, rev 2 running at 125.000MHz with memory at 125.000MHz.
000012.402|so |*|03| Board is identified as PolycomSoundPointIP-SPIP_550.
000012.402|so |*|03| DRAM_LO: 0x94000000. DRAM_SIZE: 32 MB
000012.402|so |*|03| Clocks are VBUSP: 125.000MHz, VBUS: 62.500MHz, USB: 25.000MHz, LCD: 31.250MHz, DSP: 100.000MHz.
000012.402|so |*|03| NOR flash detected is 9
000012.402|key |*|03|Initial log entry. Current logging level 4
000012.408|httpd|*|03|Initial log entry. Current logging level 4
000012.408|poll |*|03|Initial log entry. Current logging level 4
000012.408|push |*|03|Initial log entry. Current logging level 4
000012.410|poll |*|03|Initial log entry. Current logging level 4
000012.410|ht |*|03|Initial log entry. Current logging level 4
000012.410|dbuf |*|03|Initial log entry. Current logging level 4
000012.414|ssps |*|03|Application, comp. 1: Label=PolyDSP Titan Mem1 FS3, Version=6.1.1.0010 11-Jul-12 19:00
000012.414|ssps |*|03|Application, comp. 1: P/N=3150-11580-611.
000012.414|pps |*|03|Initial log entry. Current logging level 4
000012.414|sip |*|03|Initial log entry. Current logging level 4
000012.416|ptt |*|03|Initial log entry. Current logging level 4
000012.700|so |*|03|Using TCP IP Media Port, configured initial RTP port 2222
000012.754|usb |*|03|Initial log entry. Current logging level 4
000012.754|sshc |*|03|Initial log entry. Current logging level 4
000012.758|usb |4|03|soUsbInit: USB features are disabled
000012.758|cmp |*|03|Initial log entry. Current logging level 4
000012.758|wmgr |*|03|Initial log entry. Current logging level 4
000012.768|slog |*|03|Initial log entry. Current logging level 3
000012.960|app1 |*|03|Initial log entry. Current logging level 4
000012.970|app1 |4|03|StatusBar is disabled
000012.974|app1 |4|03|mb.main.home parameter is empty
000012.986|mb |*|03|Initial log entry. Current logging level 4
000013.038|app1 |5|03|pUsbRecordPlayer_m=0x9554a240, pVoiceMailPlayer_m=0x95549cf0
000013.354|ldap |*|03|Initial log entry. Current logging level 4
000013.354|ldap |4|03|cDynamicData::cDynamicData:cDynamicData:Failed
000013.390|efk |*|03|Initial log entry. Current logging level 4
000013.872|app1 |4|03|[AppUserLoginC::Init]:flushing user cache file failed
000013.906|app1 |4|03|Observable::notifyAll 1
000013.906|app1 |4|03|getCfgParams
000013.962|utilm|4|03|uBLFCompressed: File /ffs0/local/local-directory_xml.zzz does not exist or is empty
000024.022|cfg |*|03|RT|cfgRtNetInterfaceUpdate: Network not initialized
000032.676|cfg |*|03|RT|Do not do DHCP VLAN Discovery.
000032.678|cfg |*|03|RT| Phone IP address is 192.168.xxx.xxx.
000032.678|cfg |*|03|RT| Subnet mask is 255.255.255.0.
000032.678|cfg |*|03|RT| Gateway address is 192.168.xxx.1.
000032.678|cfg |*|03|RT| DNS server is xxx.xxx.xxx.xxx.
000032.678|cfg |*|03|RT| DNS alternate server is xxx.xxx.xxx.xxx.
000032.680|dns |*|03|DNS resolver servers are 'xxx.xxx.xxx.xxx' 'xxx.xxx.xxx.xxx'
000032.680|dns |*|03|DNS resolver search domain is ''
000032.684|cfg |*|03|RT|Primary IP changed to 192.168.xxx.xxx subnet mask 255.255.255.0
000032.684|cfg |*|03|RT|cfgRtNetInterfaceUpdate: bfeng -- calling network status callback
000032.692|sys |*|03|0x957d7600 (tDhcpcStateTask): arp_check: No reply, addr not used
000032.818|so |*|03|Network initialized. Starting network tasks.
000032.818|log |*|03|Install file upload callback for 'so'
000032.830|cfg |5|03|Prm|Parameter acd.reg requested type 0 but is of type 2
000032.832|sip |*|03|Fast Boot Measurement Point: Ready for Call, uptime: 32.832 sec.
000032.836|app1 |*|03|Ctx [0] Registered [false]
000032.836|app1 |5|03|Corporate directory instance does not exists.
000032.882|so |4|03|Could not find IP address for SNTP server. 86400
000032.992|utilm|4|03|uBLFCompressed: File /ffs0/local/local-directory_xml.zzz does not exist or is empty
000033.050|utilm|4|03|uBLFCompressed: File /ffs0/local/local-directory_xml.zzz does not exist or is empty
000033.070|cfg |*|03|Prov|Starting to update
000033.078|res |4|03|[ResFinderC]: Download - Failed to download file Leaf.jpg, errno 0x380003.
000033.080|app1 |4|03|Background processing failed: (Leaf.jpg): (pResult->m_result != ResFinderFound): 1.
000033.160|res |4|03|[ResFinderC]: Download - Failed to download file Sailboat.jpg, errno 0x380003.
000033.162|app1 |4|03|Background processing failed: (Sailboat.jpg): (pResult->m_result != ResFinderFound): 1.
000033.266|res |4|03|[ResFinderC]: Download - Failed to download file Beach.jpg, errno 0x380003.
000033.266|app1 |4|03|Background processing failed: (Beach.jpg): (pResult->m_result != ResFinderFound): 1.
000033.296|cfg |4|03|Prov|Download of master configuration file failed
000033.296|cfg |4|03|Prov|Trying to boot from existing configuration
000033.302|cfg |4|03|Prov|Provisioning failed
000033.310|cfg |*|03|Prov|Finished updating configuration
000033.358|res |4|03|[ResFinderC]: Download - Failed to download file Palm.jpg, errno 0x380003.
000033.358|app1 |4|03|Background processing failed: (Palm.jpg): (pResult->m_result != ResFinderFound): 1.
000033.366|log |4|03|UtilLogC::uploadFifoLog: upload error. protocol 0 result = -1
000033.374|log |4|03|Failed to upload boot log on start up.
000033.424|log |4|03|UtilLogC::uploadFifoLog: upload error. protocol 0 result = -1
000033.456|res |4|03|[ResFinderC]: Download - Failed to download file Jellyfish.jpg, errno 0x380003.
000033.458|app1 |4|03|Background processing failed: (Jellyfish.jpg): (pResult->m_result != ResFinderFound): 1.
000033.524|res |4|03|[ResFinderC]: Download - Failed to download file Mountain.jpg, errno 0x380003.
000033.526|app1 |4|03|Background processing failed: (Mountain.jpg): (pResult->m_result != ResFinderFound): 1.
003403.700|cfg |4|03|Web|[cfgSaProcessRequestC] Failed to download language file from provisioning server, request path Website_dictionary_language_en-us.xml
003403.704|utilm|4|03|uBLFCompressed: File /ffs0/languages/Website_dictionary_language_en-us.xml.zzz does not exist or is empty
003403.704|cfg |4|03|Web|[cfgSaProcessRequestC] Website_dictionary_language_en-us.xml Language file doesn't exist in cache
003403.706|cfg |4|03|Web|[cfgSaProcessRequestC] Website_dictionary_language_en-us.xml Language file doesn't exist in phone flash
