Solved Unable to deploy to aws
sibba
i tried to deploy a 3cx instance via aws several times and always got this error in the last step. The system seems to run fine (can log in to the web client) even with this error, but i can't get the credentials for the console. I tried it with several Browsers, and in aws all looks fine.
I checked for the right IAM account, key-pair, AWS region, and subscription Debian Buster 10. I followed all the steps in this guide https://www.3cx.com/docs/cloud-pbx-amazon-aws/
Maybe you can assist me what to do/try next to get this working.
We didn't have any other reports for something similar thus far, did you also happen to try from a different network and PC?
For the time being you can try using "admin" as the username and anything in the password. Two failed attempts later you should get a "Forgot password" clickable message so give that a try.
An update on this, we looked into the matter and it was indeed something on our end causing it which has now been addressed so should be fine. You can still use the method I mentioned in my previous reply to acquire the admin creds if you do not want to re-deploy.
I tried again and now it just worked fine. Thanks!
Reactions: ChrisC_3CX
You're very welcome!
Please start a new thread should you need anything else!
Reactions: ipt_dude
