Unable to migrate from self-hosted to 3CX Hosted with current self-hosted version
Robert McKeever II
When are you planning to have this version ready in Digital Ocean under your tenant?
Hosted systems are always on the latest stable version, which is currently Update 3. Update 4, which your backup is, will be loaded onto the hosted systems when it is released as stable. It is currently still in Alpha.
You can deploy a clean install of Version 20 in 3CX Hosted, then upgrade manually to update 4, as you were on your self hosted, and then restore your existing backup through the Admin console.
Reactions: N_G and Evolute IT
Good to know about the version support. Thanks.
What about the alternative port? I need to restore and it's going to bring the system to using 5001 for HTTPS.
Processing what you said, I landed with 443.
Figured it out.
Syedx91
