Solved Unable to update 3cx PBX from 16.0.4.504 to 16.0.5.611
5i3cxuser
Unable to update 3cx PBX from 16.0.4.504 to 16.0.5.611 -
I have restarted all the services manually and this has not allowed me to download the update.
I have set it to automatically update out of hours however this does nothing
I have also updated the SBC to latest version 16.1.152
When updating the pbx it simply logs me out of the management console and does not update at all.
Can you provide this info:
  • 3CX Version, e.g. Standard Annual 16.0.2.910
  • Server OS, e.g. Debian 9 / Windows Server 2012 R2 / Raspberry Pi
  • Is the 3CX Server Hosted and where?
Have you tried rebooting the machine completely and trying again?
3cx version - Standard annual 16.0.4.504
Server OS - Windows 10 Pro
Hosted in Azure
I have rebooted from the terminal however this has made no difference at all.
I did an automatic update yesterday however I have looked through the logs and there is nothing showing.
Have you checked the windows event logs?
Have you got any antivirus on that machine that could be stopping your update?
are you referring to the 3cx SBC or the PBX?
PBX is hosted in azure
3cx SBC is hosted on-prem on a windows 10 pro device.
correction:
PBX is running in amazon
Linux Debian AWS Lightsail 2 GB RAM, 1 vCPU, 60 GB SSD
A firewall is not blocking any traffic
SSH TCP
22
Any IP address
Lightsail browser SSH/RDP
HTTP TCP
80
Any IP address
HTTPS TCP
443
Any IP address
Custom TCP
5060
5061
Any IP address
Custom TCP
5090
Any IP address
Custom UDP
5060
Any IP address
Custom UDP
5090
Any IP address
Custom UDP
9000
10999
Any IP address
Can anyone help me with this i cannot find any way to upgrade the Pbx to the latest version all options ave failed so far the only other way would be to do a manual upgrade which is a last resort
Check your email: what error do you get when you try to update?
I am not receiving any email. so i cannot provide this information unfortunately
Ok, so when you press the update button, can you give us a detail description of what happens next?
Normally a failed update will send an email to the global administrator of the PBX, the one defined here under Settings > Email Settings. If this is not you, then you will not receive the email.
I have just checked the system and we do have the correct email however nothing is coming through at all.
this is the error
Hit:1 http://downloads-global.3cx.com/downloads/debian stretch-testing InRelease
Ign:2 http://cdn-aws.deb.debian.org/debian stretch InRelease
Hit:3 http://security.debian.org/debian-security stretch/updates InRelease
Hit:4 http://downloads-global.3cx.com/downloads/debian stretch InRelease
Ign:5 http://repo.saltstack.com/apt/debian/9/amd64/archive/2019.2.0 stretch InRelease
Hit:6 http://cdn-aws.deb.debian.org/debian stretch-updates InRelease
Err:7 http://repo.saltstack.com/apt/debian/9/amd64/archive/2019.2.0 stretch Release
404 Not Found [IP: 13.227.150.85 80]
Hit:8 http://cdn-aws.deb.debian.org/debian stretch Release
Reading package lists...
E: The repository 'http://repo.saltstack.com/apt/debian/9/amd64/archive/2019.2.0 stretch Release' does no longer have a Release file.
this is the error
See here: https://www.3cx.com/community/threa...eleases-with-u5-hotfix-2-and-u6-beta-2.75270/
There's many (many) posts about this already.
Reactions: 5i3cxuser
connect via SSH as root, or elevate using sudo su
Then run the following command and you should be able to update afterwards.
Bash:
wget -O - https://downloads.3cx.com/downloads/misc/debianpatches/9/16/0/5/20200619-os-update.sh | bash
Hi Thanks for all the support i have just run the command and this has worked perfectly fine without any problems the update has gone through.
Glad to hear!
footandankle.my3fcx.us
