Update to 16.0.6.655 - SBCS wont connect since
Martin.thomas747
Update to 16.0.6.655 this morning - SBCS wont connect since update, anyone else having troubles ?
3cx app doesnt work ether,
Firewall checker completed all green.
Sounds like a 3cx tunnel or fqdn issue. Can you access the management console remotely.
Try rebooting your firewall
tried that, evan setup a differnet firewall (draytek) was on sophos and the issue still present. 3cx app doesnt work ether.
Sounds like the 3CX tunnel service isn't running
  • 3CX Version, 16.0.6.655
  • Is the 3CX Server Hosted and where? 2016 Server onsite
  • IP Phone Make/Model/Firmware
  • Provisioning Method: Local SBC
  • Trunk Provider : GAMMA
SBCS are installed on remote sites on 2016 server
Cant see it anywhere in the list if honest. Check in the 3cx web gui and in local services on server, cant see in the task manager ether
3cx tunnel is not a service on the server - are all the services running except the 3cx hotel.
For a test, can you disable any firewalls on the server just in case the ports are being blocked
For portwarding on the router you have allowed tcp / udp port 5090 thru (3cx tunnel port)
Does the fqdn resolve to the wan ip of your server
It sure looks like it to me:
Evening,
So as above its somethine related to that tunnel service,
going into BIn folder and finding it, then running it brings the tunnels up.
But the exe window stays open, if you close it, it drops the tunnels.
Thanks for all your help by the way
So you don't want to run the exe manually. You want to go to services and start it from there.
it doesnt show in the services, very weird
Try creating the missing service https://itsiti.com/create-delete-windows-service-using-sc-command - run command prompt as administrator
Service name - 3CXtunnel01
Display name - “3CX PhoneSysyem 01 SIP/RTP Tunneling Proxy”
After running the command, make sure if appears in services.msc - startup as automatic, log on as - local system
Christ, ye thats a great idea ! Thanks
Working a dream
hpgitsupport
