Updated to Version Number 18.0 (Build 917)
Roy Finch
I have just updated my free version of 3CX to Version Number 18.0 (Build 917) and it keeps saying "WARNING! You are running a 3CX Free Edition. Registration is required. Do so before 31/12/23"
I have followed the info in the More info link but the message remains. I follow the guide and re-enter the owner’s email which is the original email. go back to the admin console and the message remains.
I have tried this several times, restarted the services and rebooted the server running the software, No change.
Any advice would be greatly appreciated.
Thank you.
Roy
Hi Steve,
I have had a look and I only have the one registration, only ever had the one system. Tried changing the email to a different one and it came back with already registered.:confused:
Hello @Roy Finch
The banner will remain even if you are running a unique email address as it is the same for everybody. So nothing to worry about really. It's just a warning so you have the correct setup in order for us to extend your license.
Great thank you:)
Do I understand correctly that the only way to get rid of the banner is wait until 3CX decided to remove it, or to upgrade to a non-free version ?
Correct.
3CX said in the past they will not remove it until December 2023 (and likely later)
Msplatt259
