Upgrade from v18 to v20 – Blocked Access to Hotfixes
haba-beton
I'm currently trying to upgrade from version 18 to version 20, but I'm encountering an issue where the process is blocked. The upgrade script attempts to download a file from this URL but receives a 403 Forbidden error.
When I try to access the page manually, I get the same response.
I found a related discussion in the forum:
Access Denied – Your Request Has Been Blocked
Does this mean that I won’t be able to upgrade until 3CX unblocks the endpoint?
Best regards,
Sadin Junuzovic
What update of v18 are you on?
Reactions: haba-beton
Have you received the email notification with the upgrade failure?
This notification will also include a log file with the information of the failed upgrade process.
Oh, okay – the logs indicate a different issue:
Code:
[33m====== [17:35:15] Upgrade Result: *******************************************[39m
  "result": "aborted",
  "time": "30-01-2025 17:35:15",
  "title": "File ownership problem",
  "message": "There are files under /var/lib/3cxpbx/Bin/nginx/conf with the wrong user and/or group ownership. Please make sure the files are owner by the user: phonesystem"
[31m[17:35] aborted: File ownership problem - 0[39m
I will change the file ownership to phonesystem and try again.
Thank you.
Reactions: TheodorosG_3CX
Correct, the issue is related with the custom certificates ownership.
Proceed as per message in the log and try again.
lastshadow
