- Joined
- Oct 5, 2021
- Messages
- 48
- Reaction score
- 5
Hello. Found some old V18s that we need to get upgraded. Following this article there should be an "Upgrade" button/link. I'm not seeing it.
Since we're a bit behind, did they remove it?
Also, it appears that I "MUST" pick a system before I can post this, however only V20s are an option so please ignore
Hosted,
Hosted,
- Log in to the V18 Management Console.
- As a safety precaution take a full backup configuration by going to Backup and Restore.
- Download and save your backup outside of the instance.
- Navigate to and select “Upgrade” in the top right corner.
- Confirm the upgrade.
- You will receive an email informing you when the OS and PBX are upgraded.
