Upgrade path from 16-3
bllawrence
Forum User
We are getting ready to update from 16 update 3 to 16 update 5. Will we be able to just jump straight to 16-5 or do we need to hit 16-4 first? Also, since we will be updating to the final version of 16-5 and not an alpha or beta version, do we still need to install the hotfix?
It should be a step upgrade from U3 -> U4 ->U5 but I haven't actually done that myself. All my installs were already on U4.
thanks for that info cobaltit. I should also mention, in case someone else wants to chime in, we are running 3cx on a windows server.
Should be the same regardless of OS. The only difference at this point is major version upgrades (v16 to v17). On Debian you can do those in place, and on Windows you'll have to uninstall/reinstall.
Reactions: bllawrence
As above, you keep running update until you get the latest release
U5
FYI - i would wait until the next release as there a couple of issues with u5 that may affect you.
U5
Thanks for that information. I thought the U5 final release was already out as of a week or so ago. Is there a problem with that release, Saqqara?
certain windows version had issues registering sip trunks using fqdn - this has been resolved
if you use the 3cx windows app , the sorting of contacts does not work - hopefully being fixed next week
Thanks for that information Saqqara. That is very helpful.
so does anyone know if the 16U5 release available for download has fixed the 3cx windows app issue mentioned above by Saqqara?
Available from download where? From the website or from the management console? Either way should be yes. Unless there's something wrong with your system if you update until no more are showing then you should be on the latest version which, as mentioned above, has the fix. You can also compare version numbers:
https://www.3cx.com/blog/change-log/phone-system-change-log/
the update will be via update in the management console.
no the fix has not been released
Thank you for that information.
? Yes it has. There's several threads about it and it's in the change log I linked earlier.
3K8iMGWviZ
