Solved Upload backup OVH
David Digitis
Is-it possible to upload a backup zip on OVH (pbx express) instance ? It's not a realy a "backup" but a template with defaut config il want to use on each PBX.
I can't acess folder /var/lib/3cxpbx/Instance1/Data/Backups with defaut debian user (login with key)
Thanks,
David.
Ok i have found ;)
Upload template / backup in default home user folder (debian)
sudo cp TEMPLATE1.0.zip /var/lib/3cxpbx/Instance1/Data/Backups
Regards,
David
Hi David, thanks for updating the thread
Rich Hopkins
