Solved Urgent - Installing 3CX Debian 10 ISO return to debian login after first reboot
UZZY
SOHO User
I'm installing 3CX V18 on a mini PC Below
GIGABYTE Ultra Compact Mini PC/Intel UHD Graphics 600/ M.2 SSD/HDMI (2.0A)/ DP1.2A Component- GB-BLCE-4105
It support only UEFI, i have run the ISO debian 10 from USB, it install, after first reboot to install 3CX, it never goes to 3CX installation, instead it goes to debian Login black page.
can someone help? i also tried to force UEFI, still same, can someone explain how can i install 3CX on this machine? i have to deliver this tomorrow.
thanks,
Is there possible via debian command line or Gigabyte shell command?
thanks
There is something seriously wrong here, it seems it can't install some dependencies that should be on the Debian repo.
I have sent you a PM, read it and try what I suggested.
Disable "Secure Boot" in the BIOS if it's not already off.
Via PM with @UZZY , after completely formatting the drive and restarting the process from the beginning, the installation went smoothly.
Also, not setting the Static LAN IP during the OS installation phase, rather afterwards.
Rich Hopkins
